I took the door panel off to see if there was a leak near the soap dispenser. All seemed fine. Door gasket seems fine. Lower and middle wash arms are not cracked. During operation I can observe a periodic surge of water that seems to get through the lower right side underneath the door and splash over the front of the pan. Any ideas?
