Discuss
Kenmore Ultra Wash Dishwasher - Cycles running too long
 in
Dishwasher Repair
I have a Kenmore ULTRA WASH dishwasher. Model # 165.29000 It is about six years old. The problem we seem
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Ultra Wash Dishwasher - Cycles running too long
  #1 (permalink)
Old 11-01-2009, 09:50 AM
Junior Member
mrmichaeljmoore is on a distinguished road
Default Kenmore Ultra Wash Dishwasher - Cycles running too long
Model Number: 165.29000   Brand: Kenmore   Age: 5 - 10 years
Model # 165.29000
The problem we seem to be having is the cycles seem to be running much longer than the time specified in the manual.
For example, I ran a normal wash the other night. Started it about 10pm, just before bed.
I woke up at around 1am and the cycle was still running. It was just a few clicks on the dial before the dry cycle.
According to the manual, the Normal wash should take approximately 98 minutes......
I did read that if the water is not hot enough, the heating element will come on to bring the water back to the required temp of 140 degrees.....and while the heating element is on the cycle timer stops....
My water heater is set at about 120-130 degrees, so I can understand the element needs to come on.....
but would it need to come that much that it would take nearly three hours to run, nt including the dry cycle?
Any ideas on what's the problem here?
Is the heating element bad?
Is there a thermostat that may be bad?
Thanks for the help.
mm
Related Models
Roper 1653*0A Range (gas)*
Roper 1653*1A Range (gas)*
Roper 1653*2A Range (gas)*
Roper 1653W0A Range (gas)*
Roper 1653W1A Range (gas)*
Roper 1653W2A Range (gas)*
Hoover 168691
Magic Chef 16RA-3B RV RANGE- GAS
Magic Chef 16RA-3B-49 RV RANGE- GAS
Magic Chef 16RA-3BK RV RANGE- GAS
Magic Chef 16RA-3BKZ RV RANGE- GAS
Magic Chef 16RA-3BT RV RANGE- GAS
Magic Chef 16RA-3BT49 RV RANGE- GAS
Magic Chef 16RA-3BTZ RV RANGE- GAS
Magic Chef 16RA-3BZ RV RANGE- GAS
Magic Chef 16RA-4 RV RANGE- GAS
Magic Chef 16RA-4K RV RANGE- GAS
Magic Chef 16RA-4KZ RV RANGE- GAS
Magic Chef 16RA-4T RV RANGE- GAS
Magic Chef 16RA-4TZ RV RANGE- GAS
Magic Chef 16RA-4Z RV RANGE- GAS
Magic Chef 16RB-3B RV RANGE- GAS
Magic Chef 16RB-3BT RV RANGE- GAS
Magic Chef 16RB-3BTZ RV RANGE- GAS
Magic Chef 16RB-3BZ RV RANGE- GAS
Magic Chef 16RB-4 RV RANGE- GAS
Magic Chef 16RB-4KZ RV RANGE- GAS
Magic Chef 16RB-4TZ RV RANGE- GAS
Magic Chef 16RB-4Z RV RANGE- GAS
Magic Chef 16RS-4 RV RANGE- GAS
Magic Chef 16RS-4K RV RANGE- GAS
Magic Chef 16RS-4T RV RANGE- GAS
Magic Chef 16RS-4Z RV RANGE- GAS
Magic Chef 16RW-3B RV RANGE- GAS
Magic Chef 16RW-3B-49 RV RANGE- GAS
Magic Chef 16RW-3BK RV RANGE- GAS
Magic Chef 16RW-3BKZ RV RANGE- GAS
Magic Chef 16RW-3BT RV RANGE- GAS
Magic Chef 16RW-3BT49 RV RANGE- GAS
Magic Chef 16RW-3BTZ RV RANGE- GAS
Magic Chef 16RW-4 RV RANGE- GAS
Magic Chef 16RW-4K RV RANGE- GAS
Magic Chef 16RW-4KZ RV RANGE- GAS
Magic Chef 16RW-4T RV RANGE- GAS
Magic Chef 16RW-4TZ RV RANGE- GAS
Magic Chef 16RW-4Z RV RANGE- GAS
Magic Chef 16TA-3B-49 RV RANGE- GAS
Magic Chef 16TA-3BK49 RV RANGE- GAS
Magic Chef 16TA-3BZ RV RANGE- GAS
Magic Chef 16TA-4Z RV RANGE- GAS
Magic Chef 16TB-3B RV RANGE- GAS
Magic Chef 16TB-3BK RV RANGE- GAS
Magic Chef 16TB-3BZ RV RANGE- GAS
Magic Chef 16TB-4 RV RANGE- GAS
Magic Chef 16TW-3B RV RANGE- GAS
Magic Chef 16TW-3B-49 RV RANGE- GAS
Magic Chef 16TW-3BK RV RANGE- GAS
Magic Chef 16TW-3BK49 RV RANGE- GAS
Magic Chef 16TW-3BKE RV RANGE- GAS
Magic Chef 16TW-3BKZ RV RANGE- GAS
Magic Chef 16TW-3BZ RV RANGE- GAS
Magic Chef 16TW-4KZ RV RANGE- GAS
Thermador 1701
Amana 1708.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1708.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1709.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1709.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1718.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1718.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1720.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1736.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1736.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1739.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1739.001 MWAVE - FAMILY SIZE (60 HZ)
Whirlpool 1743W0A
Roper 1745*0A 30" GAS DOUBLE OVEN RANGE
Roper 1745W0A 30" GAS DOUBLE OVEN RANGE
Amana 1750.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.001 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 17550125 GARBAGE DISPOSAL
Kenmore 17560101 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560102 DISPOSER
Kenmore 17560110 KENMORE DISPOSER
Kenmore 17560111 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560111X KENMORE DISPOSER
Kenmore 17560115 KENMORE DISPOSER
Kenmore 17560120 KENMORE DISPOSER
Kenmore 17560121 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560122 KENMORE DISPOSER
Kenmore 17560130 KENMORE DISPOSER
Kenmore 17560131 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560135 KENMORE DISPOSER
Kenmore 17560200 FOOD WASTE DISPOSER
Kenmore 17560300 KENMORE DISPOSER
Kenmore 17560350 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560351X KENMORE DISPOSER
Kenmore 17560400 KENMORE DISPOSER
Kenmore 17560400A KENMORE DISPOSER
Kenmore 17560401 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560450 DISPOSER
Kenmore 17560451 DISPOSER
Kenmore 17560452 DISPOSER
Kenmore 17560500 KENMORE DISPOSER
Kenmore 17560500A KENMORE DISPOSER
Kenmore 17560500X KENMORE DISPOSER
Kenmore 17560501 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560503 KENMORE DISPOSER
Kenmore 17560504 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560504X KENMORE DISPOSER
Kenmore 175605090 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560510 KENMORE DISPOSER
Kenmore 17560510A KENMORE DISPOSER
Kenmore 17560511 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605140 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605150 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605160 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517X KENMORE DISPOSER
Kenmore 175605250 DISPOSER (IN-SINK-ERATOR)
  #2 (permalink)
Old 11-02-2009, 02:39 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is your tech sheet
http://www.servicematters.com/docs/w...%203384557.pdf
Only you can tell, I would just be giving a wild guess.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher cycles running too long Patricia Ratliff Dishwasher Repair 3 02-08-2010 08:03 AM
Leaky Kenmore Ultra Wash Dishwasher billykid7759 Dishwasher Repair 0 01-03-2010 09:24 AM
Kenmore Ultra Wash III Dishwasher leaks Ricarno Dishwasher Repair 0 06-27-2009 12:43 PM
Kenmore Ultra Wash III Dishwasher leaks Ricarno Dishwasher Repair 0 06-27-2009 11:06 AM
Kenmore ultra wash dishwasher not draining Deejmann Dishwasher Repair 0 03-29-2009 07:54 PM
