Discuss
mysterious problem with whirlpool diswasher
 in
Dishwasher Repair
My problem is mysterious because I've replaced both the control board and the thermo limit switch already. description of problem:
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » mysterious problem with whirlpool diswasher
  #1 (permalink)
Old 07-01-2016, 07:54 PM
Junior Member
cems is on a distinguished road
Default mysterious problem with whirlpool diswasher
Model Number: WDF750SAYB3   Brand: Whirlpool   Age: 1 - 5 years
I always select hot-wash, hot-rinse, and eco-dry (normal wash only: not a "sensor" wash). three different outcomes are observed variably:
1. Sometimes the washer goes through a spray cycle but when it does, it seems not to heat the water at any point and it runs a long time.
2. Sometimes the washer heats the water (steamy vapor rushes out when the door is opened), but when it does it seems not to do a spray cycle . often the soap is in a lump at the bottom of the washer when this happens.
3. Sometimes it pumps water in, waits a minute, where it sounds like it is trying to spray for a moment then stops, it might do that twice(?) then it pumps it out. the water is not heated.
Net result is poor cleaning!
Washer is 2 years old.
Regression:
I measured a low resistance on the heater element, and as I noted it does heat sometime so evidently that can work when it wants to.
I replaced the thermal limit switch but in hindsight it was fine (both the new one and the old one read about 1 ohm at room temperature and snap to infinity when I heat them on a stove).
When I do the 1-2-3-123-123 diagnostic mode, the error codes were flashing varied codes. Usually 6-2 but sometimes just 6 flashes and no second number. One time 5-?. So I replaced the control panel with a new one. This did not solve the problem.
The water is going into it and appears to just cover the heating element. I read somewhere the water should be below the heating element? But in any event it can heat the water sometimes. Just not always.
The user accessible drain area is free of debris. I've cleaned any clogged jets in the spray arms. I don't see any other thermal sensors anywhere.
I'm stumped!
Related Models
Whirlpool WDF750SAYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF750SAYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDF780SLYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDF780SLYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF780SLYW0 UNDERCOUNTER DISHWASHER
Frigidaire WDG216RBD0 Wwh(v4) / 27 " Gas Dryer
Frigidaire WDG216RBD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG216RBD2 Wwh(v1) / Gas Dryer
Frigidaire WDG216RBW0 Wwh(v3) / 27 " Gas Dryer
Frigidaire WDG216RBW1 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG216RBW2 Wwh(v2) / Gas Dryer
Frigidaire WDG336RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG336RBD1 Wwh(v3) / 27 " Gas Dryer
Frigidaire WDG336RBD2 Wwh(v1) / Gas Dryer
Frigidaire WDG336RBS1 Wwh(v4) / 27 " Gas Dryer
Frigidaire WDG336RBSD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG336RBSW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG336RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG336RBW1 Wwh(v5) / 27 " Gas Dryer
Frigidaire WDG336RBW2 Wwh(v2) / Gas Dryer
Frigidaire WDG336RED0 Wwh(v1) / Free Standing Dryer
Frigidaire WDG336RES1 Wwh(v0) / Dryer
Frigidaire WDG336REW0 Wwh(v2) / Free Standing Dryer
Frigidaire WDG436RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG436RBD1 Wwh(v6) / 27 " Gas Dryer
Frigidaire WDG436RBD2 Wwh(v1) / Gas Dryer
Frigidaire WDG436RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG436RBW1 Wwh(v7) / 27 " Gas Dryer
Frigidaire WDG436RBW2 Wwh(v2) / Gas Dryer
Frigidaire WDG446JBS1 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG546RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG546RBD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG546RBD2 Wwh(v3) / Gas Dryer
Frigidaire WDG546RBS0 Wwh(v0) / Gas Dryer
Frigidaire WDG546RBS1 Wwh(v4) / Gas Dryer
Frigidaire WDG546RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG546RBW1 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG546RBW2 Wwh(v5) / Gas Dryer
Frigidaire WDG546RET0 RESIDENTIAL DRYER
Frigidaire WDG546RFS0 Wwh(v0) / Dryer
Frigidaire WDG546RFS1 Wwh(v0) / Dryer
Frigidaire WDG546RGS0 Wwh(v0) / Free Standing Dryer
Frigidaire WDG546RGS1 Wwh(v0) / Dryer
Frigidaire WDG547PBS0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG547PBS1 Wwh(v0) / 27 " Gas Dryer
Frigidaire WDG646RBSD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG646RBSW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG846RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG846RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDH2 Frg(v3) / Top Load Washer
Frigidaire WDLH1 Frg(v3) / 27 " Washer
Frigidaire WDLL0 Frg(v2) / 27 " Washer
Frigidaire WDLL1 Frg(v2) / 27 " Washer
Frigidaire WDLW0 Frg(v1) / 27 " Washer
Frigidaire WDLW1 Frg(v1) / 27 " Washer
Frigidaire WDMA1 Frg(v11) / Washer
Frigidaire WDMF1 Frg(v12) / Washer
Frigidaire WDMH1 Frg(v13) / Washer
Frigidaire WDML1 Frg(v14) / Washer
Frigidaire WDML2 Frg(v13) / Washer
Frigidaire WDMW1 Frg(v15) / Washer
Frigidaire WDMW2 Frg(v14) / Washer
 WDP1W Washer
 WDP1W Washer
 WDP2B Washer
 WDP2W Washer
 WDP3B Washer
 WDP3G Washer
 WDP3G Washer
 WDP3N Washer
 WDP3R Washer
 WDP3S Washer
 WDP3T Washer
 WDP3U Washer
 WDP3W Washer
Frigidaire WDP632GER0 Wwh(v0) / Dishwasher
Whirlpool WDP68805
General Electric WDRR2500K0WW WASHER
General Electric WDRR2500K1WW WASHER
General Electric WDRR2500K2WW WASHER
General Electric WDRR2500K3WW WASHER
General Electric WDRR2500K4WW WASHER
Frigidaire WDSCL2 Frg(v1) / Washer
Frigidaire WDSCL3 Frg(v1) / Washer
Frigidaire WDSCL5 Frg(v1) / Top Loading Washer
Frigidaire WDSCL6 Frg(v2) / Top Load Washer
Frigidaire WDSCLL0 Frg(v4) / 27 " Washer
Frigidaire WDSCLL1 Frg(v5) / 27 " Washer
Frigidaire WDSCLL2 Frg(v2) / 27 " Washer
Frigidaire WDSCLW0 Frg(v3) / 27 " Washer
Frigidaire WDSCLW1 Frg(v4) / 27 " Washer
Frigidaire WDSCLW2 Frg(v1) / 27 " Washer
Frigidaire WDSCW2 Frg(v2) / Washer
Frigidaire WDSCW3 Frg(v2) / Washer
Frigidaire WDSCW4 Frg(v0) / Washer
Frigidaire WDSCW5 Frg(v2) / Top Loading Washer
Frigidaire WDSCW6 Frg(v1) / Top Load Washer
Frigidaire WDSDL2 Frg(v15) / Top Loading Washer
Frigidaire WDSDL3 Frg(v11) / Top Load Washer
Frigidaire WDSDLL0 Frg(v8) / 27 " Washer
Frigidaire WDSDLL1 Frg(v8) / 27 " Washer
Frigidaire WDSDLW0 Frg(v0) / 27 " Washer
Frigidaire WDSDLW1 Frg(v7) / 27 " Washer
Frigidaire WDSDW2 Frg(v16) / Top Loading Washer
Frigidaire WDSDW3 Frg(v10) / Top Load Washer
Frigidaire WDSFW0 Frg(v1) / Top Load Washer
Frigidaire WDSLL0 Frg(v2) / 27 " Washer
Frigidaire WDSLL1 Frg(v2) / 27 " Washer
Frigidaire WDSLW0 Frg(v1) / 27 " Washer
Frigidaire WDSLW1 Frg(v1) / 27 " Washer
General Electric WDSR110T5WW WASHER
General Electric WDSR2080D0CC Washer
General Electric WDSR2080D0WW Washer
General Electric WDSR2080D2CC Washer
General Electric WDSR2080D2WW Washer
General Electric WDSR2080D4WW Washer
General Electric WDSR2080D5CC Washer
General Electric WDSR2080D5WW Washer
General Electric WDSR2080D6WW Washer
General Electric WDSR2080D7WW Washer
  #2 (permalink)
Old 04-20-2017, 06:35 PM
Junior Member
ebontrager is on a distinguished road
Default
Did you ever get to the bottom of this issue, we have the same model of dishwasher and I feel like we have a similar problem. We often find the soap tab in the bottom of the dishwasher and I don't feel like there is much of a spray cycle. I do hear it fill with water, it does get hot, but once it fills up, it just seems like nothing happens and the soap tab just sits there once it falls out of the holder. I have even run it through two cycles and still see it sitting there.
  #3 (permalink)
Old 04-20-2017, 06:49 PM
Junior Member
Default Solution
Yes I found the best solution. You remove the device labeled "whirlpool" and replace it with a Bosch Dishwasher.
Seriously,
I replaced the computer, the thermal overload, the height sensor, and the heater coil. My first whirlpool (frigidaire) lasted 3 years. It didn't help. Even worse it would work for a day or two so the problem would vanish and I'd think I must have found the problem. then it would come back. The error code stayed the say up until one day it decided to change to 6-1. But still no clean dishes. The second whirlpool gold 2.2 years. SO I'm done with Whirlpool forever. Going with Bosch
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mysterious Error Code jamie_pancake@yahoo.com Oven Repair (including Ranges and Cooktops) 0 10-16-2014 04:03 PM
LG Diswasher Run Problem JohnMc71 Dishwasher Repair 0 05-03-2014 11:42 AM
Another Bosch diswasher problem Dendra Dishwasher Repair 1 10-19-2010 11:40 AM
Bosch diswasher filling and draining problem jfiner Dishwasher Repair 1 09-16-2010 06:05 AM
mysterious thermostat Jennifer Dash Oven Repair (including Ranges and Cooktops) 3 04-27-2009 02:51 AM
