Control pad won't respond. The rinse light will come on and beep sporadically. I have killed power let set for 5+ minutes normal wash and heated dry light come on. Sometimes after reset it may work. I have already checked door interlock. The switches are functioning properly. I have continuity on heating element. Nothing looks obvious on control board or main circuit board.
