Discuss
How to replace soap dispenser on Bosch Dishwaser
 in
Dishwasher Repair
I have the replacement part AP2802340, which Bosch also called part 263088. It did not come with instructions. Can you
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » How to replace soap dispenser on Bosch Dishwaser
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-20-2008, 09:58 AM
dschimmel dschimmel is offline
Junior Member
dschimmel is on a distinguished road
Default How to replace soap dispenser on Bosch Dishwaser
Model Number: SHU9915UC   Brand: Bosch   Age: 5 - 10 years
It did not come with instructions. Can you post a response with the exact directions I need to follow to take out the old detergent dispenser and install this new one?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-14-2008, 05:31 PM
Carson1214 Carson1214 is offline
Junior Member
Carson1214 is on a distinguished road
Default
This can be tricky with sharp edges and avoiding damage to the inner door.
Remove the outer door with a T-20 torx driver. Remove 2 long screws in the top corners then remove the 6 short screws (3 each side).
Close the door and slide the outer door down and out to remove. There are some plastic block that sit on the hinges that probably will fall off they just slide back one. There for shipping so they don't need to be replaced if you can't get them back on.
Now you can see the dispenser. It is held in by a series of tabs formed by the inner door pressed into stepped ridges on the dispenser. You need to bend these out and the dispenser will pop out the door into the unit.
Now the hard part is getting the new dispenser put back in. Slide the new one back into the opening from the inside of the unit. Bend the tabs back into the dispenser take care not to bend the door as you can get a leak around the dispenser seal.
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Soap Door Doesn't Open jmccs Dishwasher Repair 7 08-06-2008 05:14 PM
soap dispenser won't open crystal Dishwasher Repair 0 12-19-2007 08:47 AM
Bosch Dishwasher Soap Tray doesn't pop open montagequeen Dishwasher Repair 5 11-30-2007 04:32 PM
Soap Dispenser Problem Gator Dishwasher Repair 1 11-05-2007 11:58 AM
Soap Dispenser romeroom Dishwasher Repair 2 09-02-2007 01:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
