Door was stuck shut after a wash,would not open. Was able to open (had to be coaxed a little) Now nothing works, no indicator lights, nothing. Micro switch on door latch works(open circuit-closed circuit) If it is the thermal fuse, how would I check to see if it is good? How would I check to see if power is getting to the control module? Any help would be appreciated. Cheers Bob
