Maytag quiet series 300 Model MDBH955AWW
Starts, adds water but not enough water before it tries to start cycling it though the dishwasher, the water never comes close to the float switch before the water stops flowing into the dishwasher. I would say it is safe to say it is only putting 2 cups of water in when it stops adding water. I changed out the water inlet valve and it didn't make a difference. Water still won't make it to the float switch before it tries to start cycling the water to the sprayers. I have been able to add water to the dishwasher with a bottle until the float switch lifts and it will run fine and wash the dishes but if I don't add more water for the rinse cycle the dishes won't get rinsed. Any ideas on what to try next?
Thank you in advance for any help. It will be greatly appreciated.
