Hi All. A couple of days ago my dishwasher suddenly stopped working. My initial research indicated that the Thermal Fuse was the likely culprit and needed replacing. Later, I think on this Forum, I learned that my dishwasher doesn't have a Thermal Fuse. In the meantime, while I was looking around for the TF I had removed the Timer to look underneath it. The Timer sits on top of a roundish piece of plastic, I believe it's called Kenmore Dishwasher Timer Cam. I don't know what the longish, rectangular piece is called. So, as you can imagine, I'm clueless on how to properly reinstall; put all this back together again. Can anyone explain how to properly reassemble the Timer parts?
