Loud noisy from dishwasher when water is going into tank. The Water Inlet Valve appears to be causing that issue. Currently ordered the part and will install as soon as the part is recieved. In the meantime I thought I would check the Chopper Assembly and clean up around it. The Chppoer Assembly was completly block with junk and a lot of debris in that area. I also order a Sump Check Valve becuase it broke pulling it out. Could this be cauing the Circulating Pump from not having the pressure to spin the Spray Arms?
