I Have A Water Leak On The Bottom Left Front Side Of The Door. It's At The Bottom Inside Part Of The Door, Where There's A White Plastic 'vent Like' Part. The Detergent Dispenser Is Above This Area On The Inside Of The Door. It Is A Very Small Leak, 1 Or 2 Drops, But It May Have Been Leaking For A Long Time Since The Wood Floor Has A Discoloration. Any Suggestions?
