Discuss
dishwasher repair
 in
Dishwasher Repair
You wrote: It does sound like the panel (keypad), Item 1 in the "Control panel" section is going. The tech
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher repair
  #1 (permalink)
Old 10-31-2009, 09:21 AM
Junior Member
lynnachester is on a distinguished road
Default dishwasher repair
Model Number: MDB5600AWB   Brand: Maytag   Age: 1 - 5 years
The tech sheet shows how to check it with a meter.
Could also be that one of the door switches is just making and pushing on the panel shuts the door enough to activate the switch.
I would try the following first in case pushing hard on the panel is moving the ribbon cable enough to get the unit going.
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Did what you suggested, I can't help thinking the door latch may be involved because all prompts work on the control panel with the exception on the start. The start will work if I open and close the door a few times and push very hard on the start. Do you still suggest replacement of the control panel or could this be the door latch??
Ads By Google
Related Models
Maytag MDB5600AWB Dishwasher - Undercounter
Maytag MDB5600AWQ Dishwasher - Undercounter
Maytag MDB5600AWS Dishwasher - Undercounter
Maytag MDB5600AWW Dishwasher - Undercounter
Maytag MDB5601AWB Dishwasher - Undercounter
Maytag MDB5601AWQ Dishwasher - Undercounter
Maytag MDB5601AWS Dishwasher - Undercounter
Maytag MDB5601AWW Dishwasher - Undercounter
Maytag MDB5651AWB Dishwasher - Undercounter
Maytag MDB5651AWS Dishwasher - Undercounter
Maytag MDB5651AWW Dishwasher - Undercounter
Maytag MDB6000AWA Dishwasher - Undercounter
Maytag MDB6000AWB Dishwasher - Undercounter
Maytag MDB6000AWW Dishwasher - Undercounter
Maytag MDB6100AWA Dishwasher - Undercounter
Maytag MDB6100AWB Dishwasher - Undercounter
Maytag MDB6100AWQ Dishwasher - Undercounter
Maytag MDB6100AWW Dishwasher - Undercounter
Maytag MDB6160AWB Dishwasher - Undercounter
Maytag MDB6160AWQ Dishwasher - Undercounter
Maytag MDB6160AWW Dishwasher - Undercounter
Frigidaire MDB631RFR0 Frg(v1) / Built - in Dishwasher
Frigidaire MDB631RFR1 Frg(v1) / Built - in Dishwasher
Frigidaire MDB631RFR2 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB631RFR3 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB631RFS0 Frg(v2) / Built - in Dishwasher
Frigidaire MDB631RFS1 Frg(v2) / Built - in Dishwasher
Frigidaire MDB631RFS2 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB631RFS3 Frg(v3) / 24 " Built - in Dishwasher
Frigidaire MDB632XFR0 Frg(v1) / Built - in Dishwasher
Frigidaire MDB632XFR1 Frg(v3) / Built - in Dishwasher
Frigidaire MDB632XFR2 Frg(v3) / 24 " Built - in Dishwasher
Frigidaire MDB632XFS0 Frg(v2) / Built - in Dishwasher
Frigidaire MDB632XFS1 Frg(v4) / Built - in Dishwasher
Frigidaire MDB632XFS2 Frg(v4) / 24 " Built - in Dishwasher
Maytag MDB6600AWB Dishwasher - Undercounter
Maytag MDB6600AWQ Dishwasher - Undercounter
Maytag MDB6600AWS Dishwasher - Undercounter
Maytag MDB6600AWW Dishwasher - Undercounter
Maytag MDB6601AWB Dishwasher - Undercounter
Maytag MDB6601AWQ Dishwasher - Undercounter
Maytag MDB6601AWS Dishwasher - Undercounter
Maytag MDB6601AWW Dishwasher - Undercounter
Frigidaire MDB662RBR0 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB662RCS0 Frg(v0) / Built - in Dishwasher
Maytag MDB6650AWB Dishwasher - Undercounter
Maytag MDB6650AWQ Dishwasher - Undercounter
Maytag MDB6650AWS Dishwasher - Undercounter
Maytag MDB6650AWW Dishwasher - Undercounter
Maytag MDB6657AWB Dishwasher - Undercounter
Maytag MDB6657AWQ Dishwasher - Undercounter
Maytag MDB6657AWS Dishwasher - Undercounter
Maytag MDB6657AWW Dishwasher - Undercounter
Maytag MDB6658AWB Dishwasher - Undercounter
Maytag MDB6658AWQ Dishwasher - Undercounter
Maytag MDB6658AWS Dishwasher - Undercounter
Maytag MDB6658AWW Dishwasher - Undercounter
Maytag MDB6800AWA Dishwasher - Undercounter
Maytag MDB6800AWB Dishwasher - Undercounter
Maytag MDB6800AWW Dishwasher - Undercounter
Maytag MDB7000AWA Dishwasher - Undercounter
Maytag MDB7000AWB Dishwasher - Undercounter
Maytag MDB7000AWW Dishwasher - Undercounter
Maytag MDB7100AWA Dishwasher - Undercounter
Maytag MDB7100AWB Dishwasher - Undercounter
Maytag MDB7100AWQ Dishwasher - Undercounter
Maytag MDB7100AWS Dishwasher - Undercounter
Maytag MDB7100AWW Dishwasher - Undercounter
Maytag MDB7130AWB Dishwasher - Undercounter
Maytag MDB7130AWQ Dishwasher - Undercounter
Maytag MDB7130AWS Dishwasher - Undercounter
Maytag MDB7130AWW Dishwasher - Undercounter
Maytag MDB7160AWB Dishwasher - Undercounter
Maytag MDB7160AWQ Dishwasher - Undercounter
Maytag MDB7160AWS Dishwasher - Undercounter
Maytag MDB7160AWW Dishwasher - Undercounter
Maytag MDB7600AWB Dishwasher - Undercounter
Maytag MDB7600AWQ Dishwasher - Undercounter
Maytag MDB7600AWS Dishwasher - Undercounter
Maytag MDB7600AWW Dishwasher - Undercounter
Maytag MDB7601AWB Dishwasher - Undercounter
Maytag MDB7601AWQ Dishwasher - Undercounter
Maytag MDB7601AWS Dishwasher - Undercounter
Maytag MDB7601AWW Dishwasher - Undercounter
Maytag MDB7650AWB Dishwasher - Undercounter
Maytag MDB7650AWQ Dishwasher - Undercounter
Maytag MDB7650AWS Dishwasher - Undercounter
Maytag MDB7650AWW Dishwasher - Undercounter
Maytag MDB7750AWB Dishwasher - Undercounter
Maytag MDB7750AWQ Dishwasher - Undercounter
Maytag MDB7750AWS Dishwasher - Undercounter
Maytag MDB7750AWW Dishwasher - Undercounter
Maytag MDB7751AWB Dishwasher - Undercounter
Maytag MDB7751AWQ Dishwasher - Undercounter
Maytag MDB7751AWS Dishwasher - Undercounter
Maytag MDB7751AWW Dishwasher - Undercounter
Maytag MDB7755AWB Dishwasher - Undercounter
Maytag MDB7755AWQ Dishwasher - Undercounter
Maytag MDB7755AWS Dishwasher - Undercounter
Maytag MDB7755AWW Dishwasher - Undercounter
Maytag MDB8000AWA Dishwasher - Undercounter
Maytag MDB8000AWB Dishwasher - Undercounter
Maytag MDB8000AWW Dishwasher - Undercounter
Maytag MDB8600AWB Dishwasher - Undercounter
Maytag MDB8600AWQ Dishwasher - Undercounter
Maytag MDB8600AWS Dishwasher - Undercounter
Maytag MDB8600AWW Dishwasher - Undercounter
Maytag MDB8601AWB10 Undercounter Dishwasher
Maytag MDB8601AWS10 Undercounter Dishwasher
Maytag MDB8601AWW10 Undercounter Dishwasher
Maytag MDB8750AWB Dishwasher - Undercounter
Maytag MDB8750AWQ Dishwasher - Undercounter
Maytag MDB8750AWS Dishwasher - Undercounter
Maytag MDB8750AWW Dishwasher - Undercounter
Maytag MDB8751AWB Dishwasher - Undercounter
Maytag MDB8751AWQ Dishwasher - Undercounter
Maytag MDB8751AWS Dishwasher - Undercounter
Maytag MDB8751AWW Dishwasher - Undercounter
Maytag MDB8751BWB Dishwasher - Undercounter
Maytag MDB8751BWQ Dishwasher - Undercounter
  #2 (permalink)
Old 11-01-2009, 03:44 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Please just use POST REPLY to your thread.
Starting a new thread each time becomes too hard to keep track of things.
So the start switch checked out OK with a meter?
The connector cleaning did nothing?
I cannot say which component is gone
You could place a short across the door switches.
Remove power from the unit when doing this.
Then close it up, reapply power and if it works OK you know it is a door switch problem.
Be careful when running this as the unit thinks the door is closed so it will start up with the door open and you will get a shower.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher Repair myracosta Dishwasher Repair 0 02-06-2010 09:23 PM
Dishwasher repair rhreed19 Dishwasher Repair 0 09-08-2009 12:53 PM
dishwasher repair cjrimer Dishwasher Repair 3 08-14-2009 07:50 AM
Dishwasher Repair bweldon4852@yahoo.co Dishwasher Repair 0 06-16-2009 12:13 PM
Dishwasher repair blk Dishwasher Repair 0 12-26-2008 06:19 PM
