notlad
#1 Posted : Wednesday, January 20, 2016 12:28:46 PM(UTC)
notlad
Dishwasher suddenly was unable to complete all steps of normal operation, so I removed and inspected all parts in bottom of tub related to water flow and found no obstructions or broken parts. Motor shaft turns freely and is not stuck. I performed basic continuity test on motor and found no open circuit problem. Control touch pad seems to be functioning properly as well. It appeared the likely culprit could be the circuit board. I ordered a new circuit board from you guys and just installed it. Dishwasher now appears to go through all steps normally, in that it fills, dispenses soap, sounds like it is running, and then empties like normal, but water does not spray during wash cycle. Does this mean the wash motor is the problem?
