I have a Kenmore Elite Dishwasher Model 665.13153K701. The machine stops working during the wash cycle. Several times the clean light was flashing and I reset the board. Now it stops and the start button is flashing as though someone has opened the door during the wash and not pressed the start button again after closing the door. The amount of time it will run before stopping varies. Sometimes it will wash for over 2 hours, other times it stops after just 20 or 30 minutes. I can usually press the start button again and it will start but the cycle never fully completes. It generally stops after the majority of washing is done and there is no water in the bottom of the tub. The dishes appear to be clean but the cycle has never completed. Eventually it stops with the start button flashing and continuing to pressing the start button again does nothing. I have to press cancel and it does the same thing the next time I run the machine.
