barnee72
#1 Posted : Thursday, January 14, 2016 5:47:55 PM(UTC)
barnee72
I have a ge profile dishwasher pdwt380r10ss. I had lots of hard water and detergent build up. I took apart the inside and cleaned everything out. The fine filter had a gasket that was falling apart. I put it back together and didn't replace the gasket. Is it ok to run the dishwasher without it? My second problem is that I have a loud humming only when water is pumping thru the unit. I have the motor off and impeller off and everything looks good. Could my moter be starting to go bad? Will replacing the impeller help? I have ran the unit with the top rack removed and it still is humming. I also put the o ring on the input for the water on the second rack. I AM VERY FRUSTRATED!! Thanks for any help!
dannyvela
#2 Posted : Wednesday, March 1, 2017 10:55:31 AM(UTC)
dannyvela
I have the same issue. I bought the filter but can´t find the replacement part for the seals/gaskets. Do you installed it without anything? any issues?
Do you know why the part is so deteriorated? maybe water temperature too high?
I looked at the original filter and its perimeter has a cutting edge with the deteriorated gasket. The new filter has a bent around all the perimeter and inner holes... no gasket and therefore I´m stuck with the repair.
dannyvela attached the following image(s):
GE Profile Dishwasher Hums when Off (Dishwasher Repair)
by Thom64 2/7/2022 7:19:40 PM(UTC)
GE profile dishwasher PDW9980N00SS starts then stops (Dishwasher Repair)
by cfcstl 12/15/2020 8:18:18 AM(UTC)
GE Profile Dishwasher QP 47 Can't move between different Wash programs (Dishwasher Repair)
by MTHall720 3/26/2020 11:32:29 AM(UTC)
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 11/17/2018 4:33:33 PM(UTC)
GE Profile Dishwasher lights up, but will not start (Dishwasher Repair)
by cjsrinivas 12/21/2015 8:06:27 PM(UTC)
ge profile dishwasher - nut water inlet - repair or replace? (Dishwasher Repair)
by dsynadinos 3/1/2014 5:22:20 AM(UTC)
GE profile dishwasher won't drain completely (Dishwasher Repair)
by nazia 2/25/2014 5:52:10 AM(UTC)
GE Profile dishwasher GHDA696Pss doesnt drain completely (Dishwasher Repair)
by jdn9580 1/11/2014 10:15:13 AM(UTC)
ge profile dishwasher (Dishwasher Repair)
by rickcallaway 11/4/2013 8:17:53 AM(UTC)
GE Profile dishwasher motor fan (Dishwasher Repair)
by saegsblair 9/19/2013 5:45:58 AM(UTC)
GE Profile Dishwasher won't drain (Dishwasher Repair)
by tms101 9/14/2013 9:47:52 PM(UTC)
GE Profile dishwasher not cleaning well (Dishwasher Repair)
by edjr 3/30/2013 4:25:14 AM(UTC)
GE Profile Dishwasher - Constant Buzzing (Dishwasher Repair)
by diydaddy 1/25/2013 9:49:05 AM(UTC)
GE Profile Dishwasher will not fully drain (Dishwasher Repair)
by springerider 1/6/2013 6:30:22 PM(UTC)
GE Profile dishwasher tripping circuit (Dishwasher Repair)
by Ale17 12/6/2012 7:54:38 PM(UTC)
