I have a Bosch SHU3307 that has had the control panel replaced under the recall program (yellow label, 15amp heater relay). The problem now is that the dishwasher cycle is as follows when a new cycle is started:
1) machine drains 2) machine starts to fill 3) during fill, the circulation motor starts 4) about a minute after the circulation motor starts, the fill stops, the machine drains, however the circulation motor continues to run. 5) If water is manually poured into the machine after #4 is done, it will run the cycle.
The machine does not have any leaks, the bottom pan is dry, the float switch and fill level switches function. Also the flow switch also is functioning.
Any tips?
