The HI TEMP LED will not light when pushed before starting a wash cycle. The Heated Dry does light up and work. Any suggestions on what to check? Also, after starting the diagnostic cycle, how do I read the diagnostic codes? Blinking light sequence? I do have a VOM to make measurements.
Thanks, Eric
