So Im having severe issues with this dishwasher. Before the warranty expired the pump motor and control panel were replaced. Now it isnt heating again and I get a drain pump motor error again. Im using a self ranging DVOM for tests. After testing I found the motor to have 36ohms (supposed to be 15-25O). And the drain pump triac is showing 13.89 MOHM (Mega ohms!) Im assuming the triac is bad but Ive never tested one so I dont know. Is this correct? The error codes I get are: 8-2 Drain Motor electrical problem 7-1 No heat 6-6 cool water Im leaning to a control panel and/or a drain motor. Or a new D/W.
