Hi I have a KitchenAid KUDS01FLSS6 and the soap dispenser door is not opening. I removed the kickplate but no tech sheet to be found (prior homeowner must have lost it). The door does open when i run the diagnostic cycle, so what do i do next? does this leave me with either a) faulty wiring from control board to dispenser, or b) a defective control board? I have a multi-meter but am unsure of how to check continuity of the wires between the dispenser and the control board. Any help would be appreciated! thanks, Todd
