herman
#1 Posted : Tuesday, September 8, 2015 11:12:56 AM(UTC)
herman
door will not latch when pushed in. does the micro switch have anything to do with the latch? thank so much for your help
#2 Posted : Wednesday, September 9, 2015 2:20:55 AM(UTC)
Parts for Maytag MDBH979AWB3 Dishwasher - AppliancePartsPros.com
The switch just tells the unit that the door is closed.
The problem is most likely mechanical, either the latch plate or the latch itself.
herman
#3 Posted : Wednesday, September 9, 2015 5:54:24 AM(UTC)
herman
thank you. looking at the latch, i can see two pieces of white plastic. i can't see what pushes the spring loaded one up to catch the inside latch. thank you Dave (herman)
herman
#4 Posted : Thursday, October 1, 2015 7:47:21 AM(UTC)
herman
maytag dw door latch would not allow dw to close but if i held it shut i would get some lights. i replaced door latch door closed but no lights, nothing just wouldn't start. power ok. i called they said order the control panel i'm not quite sure what to do. also how does that control panel come out, i see tabs on the left but i'm not sure , cause they are hard to push. thank you much for your help dave
#5 Posted : Friday, October 2, 2015 4:07:52 AM(UTC)
Below is a link to the tech sheet.
It is too large to upload to this site so I had to use a third party site.
Uncheck "Use our download manager and get recommended downloads"
This should ensure that you do not download any software that you do not want on your computer
Download SVD48600.pdf
Perhaps the video will help.
Part number: AP4588346
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
#DW80F600UTS Samsung Dishwasher High Temperature Heating Error (Dishwasher Repair)
by Guest 1/24/2024 6:35:24 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
KDTE554CSS3 Dishwasher (Dishwasher Repair)
by olderwhite@yahoo.com 1/13/2024 10:34:56 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
