The display seems to work fine. It shows "open door" when the latch is lifted. touch panel for the most part is unresponsive but occasionally will cause the display to light up with cycle information and a time of "66" but nothing happens and the display goes out after a few seconds.
I need service information for this machine. Even the sequence to enter diagnostics would help. The sequence for the diagnostics I found so far do not work as the button labels are quite different. I have three classes of buttons: wash selection, special options and energy saver options. Each has three buttons for a total of nine plus start and cancel/reset.
Keshka
