I have an LG LDF6810ST dishwasher and I am replacing the main control board. the original part number for the board is 6871DD1006D but is has been replaced with the 6871DD1006H. There are a couple of connectors on it that appear to be reversed. There are two connectors where the power seems to connect one is a three prong connector that is red and the other is a three prong that is white. their positions are reversed on the replacement board and I am wondering if I keep the connectors color coded when I swap out the board or do I plug them in to the same location regardless of the color. They are the same connector so they will fit into the other color, I am just wondering it I should keep red with red and white with white as the original was or if I swap them according to the position on the new board.
