What tells the brain of the DW to start emptying when first the unit is operated? What tells it to start filling after the drain pump does its thing?
Mine won't advance to 'fill' ; emptying pump just keeps on turning.
Door opened or closed does not affect it. I guess that's a anti-flood thing? But is there a door switch?
Might the water inlet valve be bad?
