Hi All,
I'm new to the forum. It seems the DW is not spraying. The water sounds like it loads into the DW but when it seems like it should be spraying...nothing. I hear the water empty into the garbage disposal. Everything seems to work except the spay. Our electrical service was interrupted for about 2 days. After the power returned, the DW has had it's problem. The DW was not running at the time of power outage. Any help is appreciated.
Thank you,
