My Thermador dishwasher runs and goes through all cycles, it will drain and fill with no problem. It's not pumping high water pressure to wash the dishes. I keep it clean, we have soft water to it and we clean it every few months with CLR. I have checked the pump for anything blocking it and nothing. Is there a different speed it should be running in, it is not shooting out much water through the spray arms.
Need help with this. Jgrose
