the inside of the dishwasher on the left front side is slowly leaking water non stop. why????
Here are your parts Replacement parts for GE GSD2001J01WW | AppliancePartsPros.comRemove the kick plate so you can see what is leaking. The overfill switch is on this side. Remove the float cover and check the float assembly. Sometimes crud can build up in here and it will wick water up and cause a leak. Also the water valve is on that side behind the kick plate. If it is not obvious a small mirror and a flashlight will help you find it. |
THIS FORUM IS DEAD!!!!!!! |
