| » Wiring water control valve & replacing drain hose |
Model Number: SHU3305UC/UC12 Brand: Bosch Age: 5 - 10 years
Took off the water control valve and didn't tag wires... long story it was going in garbage until I found the dishwasher was recalled. I had the recall for the control panel repaired and decided to replace the water valve and the drain hose. There are 3 wires: Purple, Green with Yellow stripe and a White wire. Water control valve has 3 male spades, one reads 110/120v the other 60hz and the other im assuming is a ground. Which wire go where?
Also want to replace the drain hose as it is brittle at the bend into the kitchen base cabinet. Do I remove the base or the side to get to the start of the drain hose? Thanks in advance... George in Cleveland Ads By Google Related Models |
Can't locate wiring diagram anywhere. Called Bosch and they will not provide me one unless I'm a tech. Suggested I call for service. OK $100 for a service call and repair to plug a wire in. Any help greatly appreciated!
George |
| Display Modes | |
| Dish Washer drain hose needs replacing | Tim Peppel | Dishwasher Repair | 0 | 07-11-2009 10:47 PM |
| Water valve hose for ice | Ed Thwaite | Refrigerator & Freezer Repair | 1 | 05-07-2009 01:12 PM |
| Hose connection to Water Valve | wirelessrulz | Refrigerator & Freezer Repair | 1 | 12-29-2008 03:35 PM |
| Bosch water valve wiring | harelt | Dishwasher Repair | 7 | 10-30-2008 11:16 AM |
| Replacing Drain Hose on Bosch Dishwasher | Lorenzo | Dishwasher Repair | 3 | 10-02-2008 11:31 AM |
