scott.madison
#1 Posted : Friday, June 12, 2015 2:10:50 PM(UTC)
scott.madison
Hello, we have a Frigidaire/Electrolux FFBD2411NS0A and there are no lights/leds on the control panel. With door completely closed, there is 120 volts at P1 and P3-7 connection points on the control board which I think implies the door switch is good. Float switch appears to be good although not sure that matters at this point. With the door closed, voltage checks at the control board follows:
P3-7(neutral) to P3-1=0 volts
P3-7(neutral) to P3-2=0 volts
P3-7(neutral) to P3-3=0 volts
P3-7(neutral) to P3-4=0 volts
P3-7(neutral) to P3-5=0 volts
P3-7(neutral) to P3-6=120 volts
P3-7(neutral) to P8=0 volts
P3-7(neutral) to P3-9=11.5 volts
P3-7(neutral) to P3-10=11.5 volts
Any help would be appreciated.
