Help! I have a Kenmore dishwasher that the soap door won't open during cycle. Easy right? Wrong. First I replaced the switch that triggers the door to pop open. Did not fix the problem. Ok so it must be the main board? So I replaced the main board. Still did not fix the problem. All of the linkage works fine to trip the door open, so the problem still must be that there is no power getting to the switch to open it? I find no broken wires or bad connections. I have tested the new switch and it works fine as did the old one. Any ideas???? Thanks!
