Discuss
Drain & Wash Impeller Kit Installation
 in
Dishwasher Repair
Dishwasher has developed leak that appears to be the result of water getting past the motor shaft seal. Plan to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Drain & Wash Impeller Kit Installation
  #1 (permalink)
Old 02-18-2008, 06:49 PM
OldAmerican OldAmerican is offline
Junior Member
OldAmerican is on a distinguished road
Default Drain & Wash Impeller Kit Installation
Model Number: KUDS24SEWH1   Brand: Kitchen Aid   Age: 5 - 10 years
Dishwasher has developed leak that appears to be the result of water getting past the motor shaft seal. Plan to purchase a drain & wash impeller kit to fix the problem. Was wondering if I need to also purchase the pump centering tool for this operation.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-19-2008, 04:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Before you do any repairs I need you to check if the motor bearing are not damaged by water leaking inside.
If the motor is more noisy then usual - the whole pump & motor assembly has to be replaced.
If the motor is fine and you are going to fix the pump I would recommend to buy the centering tool to insure the proper installation of the bottom seal.
- The part number for the drain & wash impeller kit is AP3115180
- The part number for the pump & motor assembly is AP3776341
- The part number for the pump housing centering tool is AP2908817
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDS24SEWH1
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-19-2008, 06:30 PM
Junior Member
Default
Gene-
Thanks for the reply back. The motor sounds fine and the leak has not been there long. It started after I had opened it to see why it was leaving water at the end of the cycles, thought it was the impeller but turned out to be a blocked check valve. Apparently when I was attempting to remove the first impeller I did something to a seal and thus my desire to replace the shaft seal. By the way, is there a trick to removing that screw that holds the impeller?
  #4 (permalink)
Old 02-19-2008, 07:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sometimes the impeller has to be broken in pieces and the same about the second impeller.
__________________
  #5 (permalink)
Old 02-20-2008, 04:41 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I use a sharp wood chisel to bust the impeller and limit a lot of pounding on the pump shaft.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Impeller Kit - do I need centering tool abartelpa Dishwasher Repair 0 02-16-2008 06:09 AM
GE Washer Tank Fills but No Spin/Wash/Drain jrgreulich Washer Repair 3 09-02-2007 06:09 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 09:38 AM
Noisy Pump, Impeller Now Broken? metman Dishwasher Repair 5 08-11-2007 06:09 PM
After wash cycle will not drain and spin out IndianaPanda Washer Repair 0 08-08-2007 01:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
