The model 626636 ice maker in my Kitchen aid KTRC22ELSS01 seems to be overflowing after tray is full. It slowly drips until it freezes up. It takes a few extra seconds to start cycle but then it cycles correctly. Maybe it needs extra time to defrost the ice from the trays.
I suspect the control valve isn't shutting off completely. How can I test this to determine whether failure is with the shut off valve or the ice maker itself?
