| » Leaking dishwasher |
This one woke me up to GE quality. A relatively new, builder installed GE dishwasher started leaking from the right side. Even though it was keeping my tile grout clean I opted for a new dishwasher (not GE). When I removed the machine the cause of the leak became clear. The body of the machine was bowed outward making it impossible for the door gasket to seal properly. Isn't that a beaut?
Good Morning Gene,
The tip that you gave me was right on the money. I didn't have to change the latch, my problem was that we were not closing the detergent door when we started the wash cycle. Thanks Don Evans |
Hi Gene,
I'm sorry for the confusion. I took the inner side of the door off and the soap dispenser appears to be working properly. The dishwasher is actually leaking on the left side not the right. I tighten all of the screws pretty tight when replacing the door, however more water seems to be comming out now then before. Thanks Don Evans |
Hi Don,
Check the vent screen (#12 on the inner door break down diagram) for any blockage. Inspect the door gasket. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Open the door while the dishwasher is running. See if the wash arm is spraying sideways from a split spray arm. Also, check to see if the dishwasher is over filled.
__________________
Hi santongiorgi,
Remove the bottom panel and check where exactly it's leaking from. Post your findings. Gene.
__________________
Whirlpool du810dwgui 1999 model leaking bottom right corner thru the door. I replaced door seal already, disassembled door and cleaned hard water deposits, do not see anything "broke".
When I stuff a little cloth inside door at bottom/end of door seal, water leak stopped. only work around though. Leak is mainly when start washer, water seems to squirt. Mark Last edited by MarkSpencer1 : 03-12-2008 at 04:57 PM. |
Hi Mark,
Remove the inner door panel and check for a leak through the latch (#3 on the inner door break down diagram). Here are the break down diagrams for the Whirlpool dishwasher Model DU810DWGU1 Gene.
__________________
I checked for leak at latch, no leak there.
As soon as the water starts going into the dishwasher, the water squirts out the bottom right corner. After I checked the latch for leak and reassembled the door, I turned the dishwasher on, the inlet water shoots from the left side across the dishwasher into the corner where the water leaks. I immediately opend the door, the inside of the door was still dry up by the latch. I cleaned all the hardwater deposits off the door prior to this test. The inlet water opening is clean with no mineral deposits. HELP! -------Thank YOU! |
| Display Modes | |
| leaking dishwasher | verne k | Dishwasher Repair | 6 | 09-15-2008 09:03 AM |
| Dishwasher leaking Jet Dry | rob g | Dishwasher Repair | 0 | 01-26-2008 03:48 PM |
| dishwasher leaking | marshalllandscape | Dishwasher Repair | 1 | 12-13-2007 09:28 PM |
| Leaking Dishwasher | warrenjr | Dishwasher Repair | 1 | 12-03-2007 06:16 PM |
| Dishwasher leaking | jeremiah | Dishwasher Repair | 3 | 11-14-2007 12:02 PM |
