Water did not drain completely after last cycle. I removed and cleaned the screen and filter. I removed the cover over the drain impeller. The impeller rotated with some resistance. No debris was found in the drain. Now the dishwasher will not run a cycle. The timer counts down. No water enters the unit and the motor humms and gives off an acrid odor.
