I have a Bosch SHE4AM12UC dishwasher that hasn't been draining. i have searched other forums and have already done the following: 1. Disassembled the drain line and made sure it was clear from drain pump to garbage disposal. 2. Disassembled drain pump and cleared impeller. 3.Cleared internal screen. The unit drained for a couple of washes but is back to where it was. The drain line runs down low through a hole in the side of the cabinet and then rises to the disposer. I have heard that it should run just below the counter top then drop below the disposal entrance and then up to the disposal. Is this correct? I also would like to know how to skip to the drain cycle on this model.
Thanks,
spike3333
