intermitant stoping during washcycle reset starts again but not always found plastic in drain motor replaced drain motor pump replaced tub thermostat replaced circuit board replaced door latching assembly replaced thermister turbidity sensor checked door switch checked float switch checked level checked for drain blockage checked upper thermostat checked fill valve checked conductivity of heating element
Called local whirlpool kenmore dealer had their recomended service guy come to fix . he could not find the problem $100. Prior experience with commercial appliance repair and have the tools. WHAT NOW PUMP MOTOR
