Dishes in top rack are not getting cleaned. APP has suggested: Fill Valve Fill valve is working and inlet screen is NOT clogged with debris.
Control Panel Diagnostic tests run, Control Panel appears to be working properly.
Water Feed to Upper Rack I am in the process of removing the various feed tubes - this is where I'm stuck: I can't get these interlocking pieces out! Is there a video for this?
Last possibility: Pump/Motor This unit is less than 2 years old - I should NOT need to replace the heart of the system is so short a time!
