My daughter was given a dishwasher that I hooked up for her to check out prior to installing. It works fantastically, but it leaks from the seam of the door. I checked and changed the door gasket and it still leaked. Then I noticed that there is about an 1/2" gap on the right side and approx. a 3/4" gap on the left between the door and the side of the dishwasher. This also happens to be the side that the leak is coming from (at the very top and the bottom). Is there anyway to adjust this/these gaps? Model PDB1600AWT
Many Thanks
