Top rack not getting clean, cleaned filter..all good. then washer quits with clean light blinking 7 times. checked heater continuity...good but changed out as it had hard water coating. Still having same problem. Ran hot water before starting washer. no change in performance. Ran hot wash with air dry. Getting steam but washer stops early with clean light blinking 7x stop repeat. Ran diagnostics many times with no change. What is next?
