i recently replaced, because of leak, the sump and diverter motor. the unit is getting water and draining, but it's not cleaning. there is soap left behind on the door after a cycle. thanks for the insight. ps the clamps that came for thehose to the pump motor were too big. i had to modify the strap to get it tight enough to keep the hose from leaking.
