tlhiv
#1 Posted : Monday, November 10, 2014 1:27:24 PM(UTC)
tlhiv
My dishwasher has recently stopped drying. I have also noticed that the "Clean" light blinks constantly, and in order to keep the "Clean" light from blinking I have to reset the dishwasher by pressing the sequence:
"Heated Dry" → "Normal Wash" → "Heated Dry" → "Normal Wash"
What is the "most common" cause for a blinking "Clean" light and a cycle which does not dry? Is this typically a heating element? Is it typically something else?
I am trying to determine how much troubleshooting I can perform by accessing the dishwasher's bottom compartment and without having to pull the dishwasher from the cabinet until absolutely necessary.
Thank you in advance!
shelly holland
#2 Posted : Tuesday, November 11, 2014 8:05:37 AM(UTC)
shelly holland
mine does not dry either! Interested to see if you get any response
#3 Posted : Wednesday, November 12, 2014 1:52:24 AM(UTC)
Just in case you do not have it see the attachment for the tech sheet.
First thing I would do is run your fingers along the heating element to make sure it's coating is OK.
If it is bubbled then that is a symptom of it being blown.
The easiest part to get at and check is the hi-limit thermostat.
Another way to dismantle the door so you can get at the control board.
Then you can measure P3 to P9. It should read about 20 ohms (heater resistance). This checks the hi-limit, the heater and the wires going to the heater.
Be sureto remove power from the unit when doing the above.
File Attachment(s):
13679K602.pdf (245kb) downloaded 5 time(s).
tlhiv
#4 Posted : Friday, November 14, 2014 3:58:00 PM(UTC)
tlhiv
Thank you for your response. I have pulled the dishwasher out from under the cabinet, and I have disconnected both leads from the heater element. The heater element is reading "no contact" with my continuity tester, and so I presume that is a pretty sure indication that the element is bad. Correct?
#5 Posted : Saturday, November 15, 2014 12:29:54 AM(UTC)
[COLOR="Blue"] Correct?[/COLOR]
Yes at least I think it is a yes.
I never use a continuity tester so am not familiar with what resistance it needs to give a no contact reading.
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Amana Dishwasher Not Drying The Dishes (Dishwasher Repair)
by mark@homeplanco.com 9/21/2020 7:32:33 AM(UTC)
Dishwasher not drying dishes (Dishwasher Repair)
by Danmrobertson 1/24/2016 9:14:27 AM(UTC)
GE dishwasher not drying dishes (Dishwasher Repair)
by dace109 1/16/2016 10:04:24 AM(UTC)
Electrolux dishwasher not drying after heater replacement (Dishwasher Repair)
by mvmone 7/1/2015 11:37:30 AM(UTC)
Dishwasher not drying, new heating element didn't help (Dishwasher Repair)
by madonid@hotmail.com 6/27/2015 9:34:02 AM(UTC)
Dishwasher not drying - high-limit/temp thermostat or heating element? (Dishwasher Repair)
by tom_in_atl 1/20/2014 7:44:08 AM(UTC)
by J-net 1/15/2014 10:51:32 AM(UTC)
Dishwasher Not Drying Dishes (Dishwasher Repair)
by CMGLAZE 1/1/2014 3:14:43 PM(UTC)
dishwasher not drying but element OK? (Dishwasher Repair)
by hamiltzp 11/26/2013 11:47:37 AM(UTC)
Dishwasher not drying but heating element is good (Dishwasher Repair)
by kgates123 8/30/2012 11:49:19 AM(UTC)
Dishwasher Not Drying and Not advancing from cycle to cycle (Dishwasher Repair)
by Travelcathy 8/12/2012 2:15:38 PM(UTC)
dishwasher not drying (Dishwasher Repair)
by venom79 5/31/2012 8:42:37 AM(UTC)
Dishwasher not drying (Dishwasher Repair)
by njbxgirl 4/28/2012 7:25:12 PM(UTC)
by frog4060 6/13/2011 4:52:31 PM(UTC)
