Discuss
Wont start - no lights on load selection butons
 in
Dishwasher Repair
So far I have done the following and can't get the dishwasher to run: shut off power at the breaker
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Wont start - no lights on load selection butons
  #1 (permalink)
Old 10-16-2014, 07:30 AM
Junior Member
paulcomi is on a distinguished road
Default Wont start - no lights on load selection butons
Model Number: Maytag 577-0   Brand: Maytag   Age: 5 - 10 years
shut off power at the breaker for 60 seconds
pressed Normal Load then Heated Dry 2 and 3 times
lifted and lowered the float in the bottom of the dishwasher
checked the door latch
The symptoms are that the dishwasher wont run when I press start button.
The only keypad buttons that will light up when pressed are Heated Dry, Hi Temp Wash and Santize.
The cycles buttons (heavy, normal, light) wont light
The start and cancel buttons dont light also.
Related Models
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
Maytag MBF2256HES REF - BOTTOM MOUNTS
Maytag MBF2256HEW REF - BOTTOM MOUNTS
Maytag MBF2256KEB REF - BOTTOM MOUNTS
Maytag MBF2256KEB11 REFRIGERATOR
Maytag MBF2256KEB2 REFRIGERATOR
Maytag MBF2256KEB3 REFRIGERATOR
  #2 (permalink)
Old 10-16-2014, 06:14 PM
Junior Member
Default
Anyone? Before I guess and start buying parts I was hoping that somebody recognize the problem
  #3 (permalink)
Old 10-17-2014, 01:44 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Could be that you are not getting any replies because the given model number does not come up.
Please check it.
Find your model number - AppliancePartsPros.com
Sounds like either the control panel (keypad) or the control board.
You need to find the tech sheet.
With luck it will have a key outputs chart so you can check the keypad with a meter and find out which part is bad.
__________________
  #4 (permalink)
Old 10-17-2014, 07:19 AM
Junior Member
Default
Thanks. The correct model number is:
mdb7609aww2
  #5 (permalink)
Old 10-17-2014, 09:03 AM
Senior Expert
APP Volunteer
Default
Parts for Maytag MDB7609AWW2 Dishwasher - AppliancePartsPros.com
Following is the tech sheet.
I had to use a third party site as it is too big to attach on this site.
Un-click the "Use Our Download Manager" and then use the grey button to download it otherwise the site may put software onto your computer that you do not want.
Download MDB7609.pdf
Check the control panel/keypad with a meter.
If it checks out OK then the control board is the more likely culprit.
You may also want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
  #6 (permalink)
Old 10-17-2014, 11:07 AM
Junior Member
Default
"Check the control panel/keypad with a meter.
If it checks out OK then the control board is the more likely culprit."
I have a meter but what's the procedure to check them?
  #7 (permalink)
Old 10-17-2014, 11:09 AM
Junior Member
Default
isny there a chance it has something to do with water sending pressure or something else jay would prevent the dishwasher from starting? Is there a way to reset this unit? Now that I see there isn't any control panel behind the loaf selection buttons I'm thinking it's something else
  #8 (permalink)
Old 10-17-2014, 01:08 PM
Senior Expert
APP Volunteer
Default
See the tech sheet, second page bottom center.
Not that would effect the lights on the control panel.
Removing power from the unit for a few minutes will reset it.
Not sure I follow.
The control panel (item 1 in section 02) is the keypad.
The control board (item 3 in section 02) is what interprets the keypad out puts and controls what the unit does.
__________________
  #9 (permalink)
Old 10-17-2014, 02:11 PM
Junior Member
Default
I'm about to pull the trigger on the control board but before I do could it be the thermal fuse?
  #10 (permalink)
Old 10-17-2014, 02:42 PM
Junior Member
Default
Never mind. I just ordered the electronic control. fingers crossed that's the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
front load washer lights are on but will not start richarddwalljr Washer Repair 1 03-28-2012 04:52 PM
All lights blinking and wont start? Tamilynn Dryer Repair 1 05-01-2011 04:20 AM
ge front loader wont start lights up teresa williams Washer Repair 0 10-05-2010 11:17 AM
Some Lights are on but wont start vykefan4life Dishwasher Repair 9 12-30-2009 09:56 PM
Has Power All Lights Up,wont Start tattydaddy Dryer Repair 1 10-12-2009 07:53 AM
