mama4girlies
#1 Posted : Thursday, October 2, 2014 7:37:11 AM(UTC)
mama4girlies
Hello! I noticed my dishes (plastic specifically) had a greasy cloudy film and nothing was drying. I saw a burned out spot on the heating element and picked up a new one locally and installed it. My uncle was in town and helped take it apart - We had a hard time disconnecting the wires on the bottom so he said "remember when you put this back together (he would already be gone) that it was hard to take apart so it will be hard to connect properly". it went back together pretty easily actually. Setting in the wires/nut/terminal went well. It wasn't hard to connect them at all. They feel secure. But no heat. Could I have another problem? Additional damage from the heating element being out? additionally, I have these small white plastic "washers" for lack of a better term and I am trying to figure out how exactly they go in...the appliancepartspro video on youtube for this element didn't show these tiny white plastic washers...
guys- I am on my own here. My uncle went back home and my dad dropped by and said "I don't know anything about dishwashers" and is dozing on my couch...
gerry d
#2 Posted : Thursday, October 2, 2014 1:03:33 PM(UTC)
gerry d
Parts for Whirlpool WDT710PAYM0: Heater Parts - AppliancePartsPros.com
here is a drawing of the heater assembly for your model
mama4girlies
#3 Posted : Thursday, October 2, 2014 2:14:10 PM(UTC)
mama4girlies
I have seen this. I put the little white washer in as noted already. I talked to a family friend who does appliance repair on the side (who doesn't have time to come over dang it) and he said double triple check that it is actually connected correctly so element will heat. Going back to do that. Again.
#4 Posted : Friday, October 3, 2014 5:21:21 AM(UTC)
Parts for Whirlpool WDT710PAYM0 Dishwasher - AppliancePartsPros.com
I do not know what the small white washers are for.
As long as there is a rubber washer on the element legs inside the dishwasher tub it should be OK as far as leaks.
Remove power from the unit.
Check the heater for resistance should be around 20 ohms.
If OK
Check the hi-limit thermostat (item 15 in section 05).
It should be 0 ohms.
IF OK
Check P4-3 to P4-4 at the control board.
You should see the heater element resistance.
If not there is a problem with the wiring.
If OK then the control board is probably bad.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
WDT710.pdf (886kb) downloaded 5 time(s).
