Discuss
Hotpoint dishwasher
 in
Dishwasher Repair
The dishes in my hotpoint dishwasher won't come clean. One suggestion I have seen is to clean the washe
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Hotpoint dishwasher
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-16-2008, 08:22 PM
Brian Ramsden Brian Ramsden is offline
Junior Member
Brian Ramsden is on a distinguished road
Default Hotpoint dishwasher
Model Number: AB915112   Brand: Hotpoint   Age: More than 10 years
The dishes in my hotpoint dishwasher won't come clean. One suggestion I have seen is to clean the washe arm. I can't get it off. I also can't find a manual or diagram to help. It has a wash tower but no visible way to loosen it to get to a screw to remove the washer arm. All the sites I have visited (Hotpoint and Camco plus other repair sites) do not even recognize my model number. I don't know what to do. Please help if you can.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-17-2008, 03:05 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check the water level, should be just below the heater, if ok, open the door a few times and check for water spray from the lower spray arm and also check that it is turning. If poor spray, twist off the tower above the lower wash arm, i think you turn it counterclockwise. Use a large adjustable pliers to do this.Then check under the wash arm for a worn gasket.
Also, remove the rear tub pump cover and check for blocking items at the pump inlet.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No heat in hotpoint history Dryer Repair 0 01-12-2008 02:48 PM
Hotpoint refrig runs continuously woodhill Refrigerator & Freezer Repair 2 01-10-2008 01:09 PM
Hotpoint Counter Saver Plus dalejennemma Heating, Ventilation, and Air Conditioning (HVAC) 0 01-05-2008 08:21 AM
Hotpoint Self Cleaning woes ckillen Oven Repair (including Ranges and Cooktops) 1 11-19-2007 01:07 PM
Hotpoint Washer Leak dperry Washer Repair 0 11-12-2007 08:53 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
