Discuss
Sears Kenmore Dishwasher Water Level Float Seal Leaking? Can it be fixed?
 in
Dishwasher Repair
Hello Yes, It can be fixed and here is how. See all the pics and detail below! Sears kenmore 18"
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Sears Kenmore Dishwasher Water Level Float Seal Leaking? Can it be fixed?
  #1 (permalink)
Old 07-12-2014, 05:20 PM
Junior Member
don2222 is on a distinguished road
Default Sears Kenmore Dishwasher Water Level Float Seal Leaking? Can it be fixed?
Model Number: 587.14432200   Brand: Kenmore   Age: 5 - 10 years
Hello
Sears kenmore 18" compact dishwasher 587.14432200 or 587.14439200
Oh-Oh, Saw the ceiling leaking water in the garage!
Nothing under the sink but the inocent dishwasher is next to it on the right.
So I pulled it out and turned it on for a test. After it filled with water the I could see that right around the stem of the water level float there was a stream of leaking water!
The stem rests on a lever to sense different water levels.
Can this be fixed? ? ?
Is this a solution? > Leaking dishwasher float - The DIY Girl
The float itself seems ok. I pulled it out like the manual said and checked it. It seams like the seal around it is failing?
The Dishwasher must be level and the hole must be clean and if there is a worn washer like a Maytag it should be replaced or the switch may be bad. In my case, the hole is clean and there is no washer. I tested the micro switch with a contimuity tester and the contacts do open and close. Could the switch lever need adjustment. I watched the washer run, it does not leak right away so could the water level be too high? What woulld fix it?
Latest
I slowly moved the float up and down by pushing the plastic lever that it was resting on up and down. I could here the switch close when the lever was pushed up, but if I slowly let the lever fall back down the switch will hang and the contacts will not open! So I took a small yankee screw driver and popped the lever out and removed the phillips screw above the lever to remove the plastic assembly that contains the micro switch. Then I removed the switch wires and cleaned the contacts and cleaned the switch lever. After reassembly the switch did not hang when testing by hand. I ran it thru the cycle now to see what happens. It started leaking a little at first when filling with water, then during the wash part of the cycle it leaked alot. While it was leaking alot I pushed up on the lever and heard the contacts of the switch click! Therefore it seams to be over filling because the switch is not stopping it at the right time. I suspect the switch is defective. See pics 9-10
See switch diagram and part pics 11 & 12
Does anyone know for sure if a new switch will fix this issue?
One of my appliance tech friends said the switch fix the problem. :-)
Last pic shows the assembly order. Thanks
See pics
Pic 1 - Inside of Dishwasher. Black arrow shows water level dectector float.
Pic 2 - Close up of water level float
Pic 3 - Manual information on float
Pic 4 - bottom of float stem sitting on round lever tab
Pic 5 - Place of water leak where stem goes through the bottom of the frame. See black arrow
Pic 6 - Top view of dishwasher with float removed. See black arrow.
Pic 7 - bottom side of float. Stem looks good or is it worn?
Pic 8 - Removing the 4 screws and the bottom panel we see the Leak in Action with the dishwasher On and washing after the fillup!
Pic 9 - Switch lever and switch removed.
Pic 10 - still leaking a little initially during the water fill and leak is streaming during the wash cycle.
Pic 11 - Manual Diagram of switch part # 5
Pic 12 - Manual Parts list shows Switch part # 154408701 A B Switch Assy,float
Pic 13 - New Float Switch assembly that should fix the problem!
No, no hair line crack in the tub just a line of hair! LOL
Hello
The saga continues,
I got the switch and installed it. During the fill cycle now, there is no soapy water leaking so that part is fixed,
However during the wash cycle, it started leaking like a sive!
So I moved it to the end of the wash cycle and let it drain out with a pan to catch most of the leaking water.
Then I opened it up and checked the wash arm.Then I saw something stuck in the end spray hole.
So I took it off and dumped out what I saw. Two hard pieces and a piece of glass.
After cleaning the pieces out, I tried it again.
During the wash cycle it was still leaking, I opened the door to look but I thought I saw nothing when in fact I really did.
After rinally viewing this, see last pic below. I did notice the water was still filling!
It says if you see it filling, then the water valve is stuck open!
https://www.youtube.com/watch?v=7NiFMxhd-pU
So now the water valve is on order!
Pic 14 - Spray Arm
Pic 15-17 - Someting in the end spray hole
Pic 18-20 - Pieces phone
Related Models
Kenmore 58711000 HARMONY HOUSE CABINET & SINK CABINET
Kenmore 58711100 HARMONY HOUSE CABINET & SINK CABINET
Kenmore 58711200 HARMONY HOUSE CABINET & SINK CABINET COMBINATIONS
Kenmore 58711300 HARMONY HOUSE CABINET & SINK CABINET COMBINATIONS
Kenmore 58711400 HARMONY HOUSE CABINET SINK
Kenmore 58711500 HARMONY HOUSE CABINET SINK
Kenmore 58711600 HARMONY HOUSE CABINET & SINK CABINET COMBINATIONS
Kenmore 58711700 HARMONY HOUSE CABINET & SINK CABINET COMBINATIONS
Kenmore 58712000 HARMONY HOUSE CABINET & SINK CABINET
Kenmore 58712100 HARMONY HOUSE CABINET & SINK CABINET COMBINATIONS
Kenmore 58713000 HARMONY HOUSE CABINET & SINK CABINET
Kenmore 58713100 HARMONY HOUSE CABINET & SINK CABINET COMBINATIONS
Kenmore 58714000100 DISHWASHER
Kenmore 58714000101 DISHWASHER
Kenmore 58714000102 DISHWASHER
Kenmore 5871400090 DISHWASHER
Kenmore 5871400091 DISHWASHER
Kenmore 5871400190 DISHWASHER
Kenmore 5871400191 DISHWASHER
Kenmore 58714001990 DISHWASHER
Kenmore 58714001991 DISHWASHER
Kenmore 58714001992 DISHWASHER
Kenmore 58714001993 DISHWASHER
Kenmore 58714002990 DISHWASHER
Kenmore 58714002991 DISHWASHER
Kenmore 58714002992 DISHWASHER
Kenmore 58714002993 DISHWASHER
Kenmore 58714003100 DISHWASHER
Kenmore 58714008001 DISHWASHER
Kenmore 58714008002 DISHWASHER
Kenmore 58714008003 DISHWASHER
Kenmore 5871400890 DISHWASHER
Kenmore 5871400891 DISHWASHER
Kenmore 587140091 DISHWASHER
Kenmore 58714009100 DISHWASHER
Kenmore 58714009101 DISHWASHER
Kenmore 58714009102 DISHWASHER
Kenmore 5871400990 DISHWASHER
Kenmore 5871400991 DISHWASHER
Kenmore 58714012400 DISHWASHER
Kenmore 58714012401 DISHWASHER
Kenmore 58714012402 DISHWASHER
Kenmore 58714012403 DISHWASHER
Kenmore 58714012404 DISHWASHER
Kenmore 58714012405 DISHWASHER
Kenmore 58714012406A DISHWASHER
Kenmore 58714013400 DISHWASHER
Kenmore 58714013401 DISHWASHER
Kenmore 58714013402 DISHWASHER
Kenmore 58714013403 DISHWASHER
Kenmore 58714013404 DISHWASHER
Kenmore 58714013405 DISHWASHER
Kenmore 58714013406 DISHWASHER
Kenmore 58714013407A DISHWASHER
Kenmore 58714014400 DISHWASHER
Kenmore 58714014401 DISHWASHER
Kenmore 58714014402 DISHWASHER
Kenmore 58714014403 DISHWASHER
Kenmore 58714014404 DISHWASHER
Kenmore 58714014405 DISHWASHER
Kenmore 58714014406A DISHWASHER
Kenmore 58714019400 DISHWASHER
Kenmore 58714019401 DISHWASHER
Kenmore 58714019402 DISHWASHER
Kenmore 58714019403 DISHWASHER
Kenmore 58714019404 DISHWASHER
Kenmore 58714019405 DISHWASHER
Kenmore 58714019406A DISHWASHER
Kenmore 5871403080 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871403180 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871403880 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871404080 BUILT-IN DISHWASHER
Kenmore 5871404081 DISHWASHER
Kenmore 5871404082 DISHWASHER
Kenmore 5871404180 BUILT-IN DISHWASHER
Kenmore 5871404181 DISHWASHER
Kenmore 5871404182 DISHWASHER
Kenmore 5871404880 BUILT-IN DISHWASHER
Kenmore 5871404881 DISHWASHER
Kenmore 5871404882 DISHWASHER
Kenmore 5871404980 BUILT-IN DISHWASHER
Kenmore 5871404981 DISHWASHER
Kenmore 5871404982 DISHWASHER
Kenmore 5871405180 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871405880 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 587140591 DISHWASHER
Kenmore 5871405980 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871406080 KENMORE BUILT IN DISHWASHER
Kenmore 5871406081 AUTOMATIC BUILT-IN DISHWASHER
Kenmore 5871406083 KENMORE BUILT-IN DISHWASHER
Kenmore 5871406085 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871406180 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871406580 KENMORE BUILT IN DISHWASHER
Kenmore 5871406581 AUTOMATIC BUILT-IN DISHWASHER
Kenmore 5871406583 KENMORE BUILT-IN DISHWASHER
Kenmore 5871406585 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871406586 KENMORE AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871406880 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871406980 AUTOMATIC BUILT-IN DISHWASHERS
Kenmore 5871409080 BUILT-IN DISHWASHER
Kenmore 5871409081 DISHWASHER
Kenmore 5871409082 DISHWASHER
Kenmore 5871409580 BUILT-IN DISHWASHER
Kenmore 5871409581 DISHWASHER
Kenmore 5871409582 DISHWASHER
Kenmore 58714100 HARMONY HOUSE CABINET & SINK CABINET COMBINATIONS
Kenmore 58714102800 DISHWASHER
Kenmore 58714112400 DISHWASHER
Kenmore 58714112401 DISHWASHER
Kenmore 58714112402 DISHWASHER
Kenmore 58714113400 DISHWASHER
Kenmore 58714113401 DISHWASHER
Kenmore 58714113402 DISHWASHER
Kenmore 58714114400 DISHWASHER
Kenmore 58714114401 DISHWASHER
Kenmore 58714114402 DISHWASHER
Kenmore 58714119400 DISHWASHER
Kenmore 58714119401 DISHWASHER
Kenmore 58714119402 DISHWASHER
Kenmore 58714131100 DISHWASHER
Last edited by don2222 : 07-21-2014 at 06:12 PM. Reason: add pic of new replacement part to fix the issue
  #2 (permalink)
Old 07-14-2014, 09:27 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
The pictutre showing the bottom of the tub with the float removed looks to me like there is a crack/hole here.
The receiver is part of the tub so I would say that it is not repairable.
__________________
  #3 (permalink)
Old 07-18-2014, 08:35 PM
Junior Member
Default Still leaking during fill cycle only now
Hello
It looked like a hair line crack but was just a line of dirty hair! LOL
So I found this video. Video says if you open the door and it is still filling then the valve is stuck open!. That is what I saw!
Then I ordered another part - The water valve. Will this fix it?
Pic 21 - Filling water that should not be seen!
Pic 22 - Water valve now on order!
File Type: jpg SeeingTheWaterFilling-TheSmokingGun.jpg (23.0 KB, 11 views)
  #4 (permalink)
Old 07-19-2014, 02:30 AM
Senior Expert
APP Volunteer
Default
I cannot say for sure but the odds are good.
__________________
  #5 (permalink)
Old 07-21-2014, 06:09 PM
Junior Member
Default Dishwasher is now fixed! It does not leak a drop!
Hello
Well the 1st part, the float switch fixed the small leak when the water was filling!
The 2nd part, the water fill valve that was sticking, fixed the major leak during the wash cycle because the valve stuck open and put too much water in the dish washer!
Dishwasher ran through every cycle without leaking a drop!
See pics of Final Fix!
Pic 1 - New part came priority mail because we did not want to wait another 5 days!
Pic 2 - This part is white not yellow like the old one and the water connection goes strait back not on a 45 degree angle. Looks like a 3rd party part! ! !
Pic 3 - Old part has brass elbow attached, Is this to make it harder for a DIY person so you have to call in a plumber? Not in my case!
Pic 4 - Using a vise grips and my bench vise I easily got the brass elbow off! Now have to clean the old adheasive off with the drill driver!
Pic 5 - Using my favorite FTP paste that I use on boiler connections works great here!
Pic 6 - Back in the vise to tighten the brass elbow onto the water fill valve!
Pic 7 - cranking the ss braided inlet water connection on.
Pic 8 - slipping the black rubber hose water outlet to the dishwasher back on
Pic 9 - sliding the wire connector back on
Pic 10 - mounting the fill valve bracket back on the dishwasher
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dishwasher Died-water up to float in tub, Vacuumed water & drain lines STEVE DOE Dishwasher Repair 1 12-06-2013 12:55 AM
Dishwasher water level WAY too high and leaking paulevansonline Dishwasher Repair 0 01-13-2012 06:36 PM
Dishwasher Leaking froim Underneath at the Float Switch crawas Dishwasher Repair 0 09-09-2011 07:21 AM
Kenmore 665 Leaking from float switch hw737 Dishwasher Repair 0 10-06-2009 03:10 PM
Kenmore dishwasher not spraying water at the third level ilikebikes Dishwasher Repair 1 10-17-2007 03:34 PM
