| » Soak Light flashing |
Model Number: DU1100XTPB6 Brand: Whirlpool Age: 1 - 5 years
Soak light is flashing, dishwahser will not start
Cancel doesn't do anything either. When unplugged and plugged again, soak light comes on flashing. After hitting few keys, normal starts blinking again along with the Soak/Scour light. I had this problem before, and i think i tried some combination (rinse-dryheated) or soemthing like that, but it didn't do trick this time. Please advise. Ads By Google Related Models |
Replacement parts for WHIRLPOOL DU1100XTPB6 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%208535451.pdf Sounds like it may be a stuck key. Check the keypad out with a meter see the tech sheet. You may also want to try the diagnostics. If the keypad checks out then you may want to try the following though usually it only works for open keys. Connector Cleaning Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
| Display Modes | |
| Whirlpool Quiet Partner II dishwasher soak light flashin g | nadeem2009 | Dishwasher Repair | 0 | 10-23-2009 07:55 PM |
| Flashing rinse only light | bhop26 | Dishwasher Repair | 0 | 03-20-2009 02:01 PM |
| flashing light | tsue | Dishwasher Repair | 0 | 10-07-2008 09:45 AM |
| Cancel light flashing | Jaxeldr2 | Dishwasher Repair | 4 | 09-11-2008 06:45 AM |
| quiet partner III soak and scour light flashing | dbout | Dishwasher Repair | 0 | 06-27-2008 05:37 PM |
