Discuss
Drain error code 11
 in
Dishwasher Repair
Please help. Receiving error code 11. Drain error. I tested the drain pump with both tester and rigged up to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Drain error code 11
  #1 (permalink)
Old 06-24-2014, 08:02 PM
Junior Member
Rescue161 is on a distinguished road
Default Drain error code 11
Model Number: EWDW6505GS0B   Brand: Electrolux   Age: 1 - 5 years
Please help. Receiving error code 11. Drain error. I tested the drain pump with both tester and rigged up to electric and operates. Cleaned out entire inside drain which was mostly clean. Took apart the drain valve. ball and inside was mostly clean. Test with tester showed good but not sure because there are 4 electrical connections. Two show good electric. Mushroom inside showed good when tested with electrical tester. All hoses clean. Only thing really left is the control panel unless the drain valve is bad. Went to parts store and tested new valve before purchase and it tested the same as old part so I believe that is good.
Please help. Any suggestions? Thank you.
Related Models
 EWDW6505GS0B DISHWASHER
 EWDW6505GW0 DISHWASHER
 EWDW6505GW0B DISHWASHER
 EWED65HIW0 DRYER
 EWED65HSS0 DRYER
 EWED65HTS0 DRYER
 EWFLS65IIW0 FRONT LOAD WASHER
 EWFLS65IMB0 FRONT LOAD WASHER
 EWFLS65IRR0 FRONT LOAD WASHER
 EWFLS65ISS0 FRONT LOAD WASHER
 EWFLS65ITS0 FRONT LOAD WASHER
 EWFLS70JIW0 WASHER
 EWFLS70JMB0 WASHER
 EWFLS70JRR0 WASHER
 EWFLS70JSS0 WASHER
 EWFLS70JTS0 WASHER
 EWFLW65HIW0 WASHER
 EWFLW65HSS0 WASHER
 EWFLW65HTS0 WASHER
 EWFLW65IMB0 WASHER
 EWFLW65IRR0 WASHER
 EWGD65HIW0 DRYER
 EWGD65HSS0 DRYER
 EWGD65HTS0 DRYER
 EWMED65HIW0 DRYER
 EWMED65HSS0 DRYER
 EWMED65HTS0 DRYER
 EWMED65IMB0 DRYER
 EWMED65IRR0 DRYER
 EWMED6CHIW0 DRYER
 EWMED6CHSS0 DRYER
 EWMED6CHTS0 DRYER
 EWMED6CIRR0 DRYER
 EWMED70JIW0 DRYER
 EWMED70JMB0 DRYER
 EWMED70JRR0 DRYER
 EWMED70JSS0 DRYER
 EWMED70JTS0 DRYER
 EWMED7CJIW0 ELECTRIC DRYER
 EWMED7CJMB0 ELECTRIC DRYER
 EWMED7CJRR0 ELECTRIC DRYER
 EWMED7CJSS0 ELECTRIC DRYER
 EWMED7CJTS0 ELECTRIC DRYER
 EWMGD65HIW0 DRYER
 EWMGD65HIW1 DRYER
 EWMGD65HIW2 DRYER
 EWMGD65HSS0 DRYER
 EWMGD65HSS1 DRYER
 EWMGD65HSS2 DRYER
 EWMGD65HTS0 DRYER
 EWMGD65HTS1 DRYER
 EWMGD65HTS2 DRYER
 EWMGD65IMB0 DRYER
 EWMGD65IMB1 DRYER
 EWMGD65IMB2 DRYER
 EWMGD65IRR0 DRYER
 EWMGD65IRR1 DRYER
 EWMGD65IRR2 DRYER
 EWMGD70JIW0 DRYER
 EWMGD70JMB0 DRYER
 EWMGD70JRR0 DRYER
 EWMGD70JSS0 DRYER
 EWMGD70JTS0 DRYER
Whirlpool EWT8001A00 REFRIGERATOR
Whirlpool EWT8001D00 REFRIGERATOR
Whirlpool EWT8001Q00 REFRIGERATOR
Whirlpool EWT8002A00 REFRIGERATOR
Whirlpool EWT8002Q00 REFRIGERATOR
Whirlpool EWT8502A00 REFRIGERATOR
Whirlpool EWT8503A00 REFRIGERATOR
Maytag EWU1005 DISHWASHER- UNDERCOUNTER
Maytag EWU304 DISHWASHER- UNDERCOUNTER
Maytag EWU384 DISHWASHER- UNDERCOUNTER
Amana EX1010.000 COMMERCIAL MICROWAVES
Amana EX1065.000 COMMERCIAL MICROWAVES
Amana EX2010.003 COMMERCIAL MICROWAVES
Amana EX2010.013 COMMERCIAL MICROWAVES
Amana EX2010.A COMMERCIAL MICROWAVES
Amana EX2010.A03 COMMERCIAL MICROWAVES
Amana EX2010.B COMMERCIAL MICROWAVES
Amana EX2050.012 COMMERCIAL MICROWAVES
Amana EX2075.012 COMMERCIAL MICROWAVES
Amana EX2075.B COMMERCIAL MICROWAVES
Amana EX2485.000 COMMERCIAL MICROWAVES
Amana EX2485.A COMMERCIAL MICROWAVES
 EXV1511B Microwave Oven
 EXV1511BS Microwave Oven
 EXV1511W Microwave Oven
Hardwick F-150 RANGE- F/S STD ELE
Hardwick F-414 SURFACE UNIT- GAS
Hardwick F-434 SURFACE UNIT- GAS
Hardwick F-436 SURFACE UNIT- GAS
Hardwick F-444 SURFACE UNIT- GAS
Hardwick F-446 SURFACE UNIT- GAS
Frigidaire F04B322BDA Frg(v1) / Electric Range
Frigidaire F04B322BDB Frg(v1) / Electric Range
Frigidaire F04B322BDC Frg(v1) / Electric Range
Frigidaire F04B322BWA Frg(v2) / Electric Range
Frigidaire F04B322BWB Frg(v2) / Electric Range
Frigidaire F04B322BWC Frg(v2) / Electric Range
Frigidaire F04B350BDA Frg(v1) / Electric Range
Frigidaire F04B350BDB Frg(v1) / Electric Range
Frigidaire F04B350BDC Frg(v2) / Electric Range
Frigidaire F04B350BDD Frg(v1) / Electric Range
Frigidaire F04B350BWA Frg(v2) / Electric Range
Frigidaire F04B350BWB Frg(v3) / Electric Range
Frigidaire F04B350BWC Frg(v4) / Electric Range
Frigidaire F04B350BWD Frg(v2) / Electric Range
Frigidaire F04B350EDA Frg(v1) / Electric Range
Frigidaire F04B350EDB Frg(v1) / Electric Range
Frigidaire F04B350EDC Frg(v2) / Electric Range
Frigidaire F04B350EWA Frg(v2) / Electric Range
Frigidaire F04B350EWB Frg(v3) / Electric Range
Frigidaire F04B350EWC Frg(v4) / Electric Range
Frigidaire F04B357BDA Frg(v1) / Electric Range
Frigidaire F04B357BDB Frg(v1) / Electric Range
Frigidaire F04B357BDC Frg(v1) / Electric Range
Frigidaire F04B357BDE Frg(v1) / Electric Range
Frigidaire F04B357BDF Frg(v1) / Electric Range
Frigidaire F04B357BDG Frg(v1) / Electric Range
  #2 (permalink)
Old 06-25-2014, 06:41 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Electrolux EWDW6505GS0B Dishwasher - AppliancePartsPros.com
Here is a link to a manual.
I am not sure if it will work for you.
If not let me know and I will try to put it on another site so you can get it.
http://www.emaservicetips.com/pdfs/4...Dishwasher.pdf
I am not sure that I am reading the error properly but I think that the unit is looking for a valve open which would be that the position switch is closed so I would check the wires/connector going to the switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F1-8 Code, disconnected touchpad ribbon, then F1-7 error code sstark Oven Repair (including Ranges and Cooktops) 1 09-01-2014 09:41 AM
Kenmore Elite Calypso Model 110.22062102 Gives Error Code LD after final drain gstevens Washer Repair 2 08-05-2014 05:23 AM
Washer won't drain, but makes noise error code "FL" Replacement Washer Repair 0 12-25-2012 05:28 PM
LG error code OE - drain error JPotter Washer Repair 0 04-01-2011 07:20 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
