Hello: The circulation motor hums but won't start. I can turn the rotor with a stick. Would this be the motor or the capacitor? How do I check to find out which it is? Are these parts even available anymore? If not, can I substitute another motor from a different model? Can the motor be repaired?
Thanks for any help, David Long
