I only wish it was a simple gasket repair. Instead, it appears that I'll be stuck replacing the entire instantaneous water heater assembly. Dishwasher leaks (fast drip) below tub near back of unit only while running. It is leaking from these two holes: It continues dripping into the base of the dishwasher until the water level is high enough to float the styrofoam disk which trips some kind of 'flood mode' which never goes off until the leaked water is removed from the base. In fact, it will run even when the dishwasher door is open. Please advise.
