Discuss
Frigidaire door seal.. is it working?
 in
Dishwasher Repair
I just replaced a lower door seal on my dishwasher with part #154576501. It was an exact match for the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Frigidaire door seal.. is it working?
  #1 (permalink)
Old 05-29-2014, 10:13 AM
Junior Member
cj_mcnix is on a distinguished road
Default Frigidaire door seal.. is it working?
Brand: Frigidaire   Age: 5 - 10 years
I just replaced a lower door seal on my dishwasher with part #154576501. It was an exact match for the old one. I only replaced it because some rubber bit had separated from the plastic and was dangling like a streamer.
I replaced the seal successfully (I think). However, I decided to run a full cycle with the front panel off to monitor the seal. I'm quite concerned now as I can see water lapping into what appears to be a trench under the door. The water does not go over the trench lip and I have no leaks on the floor or anywhere else. The trench also appears to have a "high tide" line where clean plastic ends and crud begins. It also empties out completely when the water is draining out through the pump.
Is this normal? The lower door seal doesn't have a lot of rubber on the edge, so I'm hoping someone is going to tell me it's okay!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace oven door seal and assembly door Elizabeth Bunting Oven Repair (including Ranges and Cooktops) 1 09-14-2013 01:48 PM
Kenmore fridge door will not seal but freezer door is fine ril458 Refrigerator & Freezer Repair 1 07-10-2012 05:13 AM
Frigidaire Door Seal steve-r Dishwasher Repair 6 12-18-2008 01:26 PM
Replaced Door seal, door wont close ggreen3 Dishwasher Repair 3 12-18-2008 09:17 AM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 03:42 AM
