Discuss
Bosch dishwasher drain pump cycling on off
 in
Dishwasher Repair
Hi, I'm having a strange issue with my Bosch dishwasher, model number SHX43C05UC/50. It has always worked fine since I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher drain pump cycling on off
  #1 (permalink)
Old 05-20-2014, 07:51 PM
Junior Member
RoberTX is on a distinguished road
Question Bosch dishwasher drain pump cycling on off
Model Number: SHX43C05UC/50   Brand: Bosch   Age: 5 - 10 years
It has always worked fine since I moved into this home about 4 years ago. Yesterday when I tried to push the ON button to turn it on, nothing happened. Normally, the wash selection (regular, power scrub...) light will turn on. I checked the circuit breaker, and then verified 120 V at the dishwasher terminal block (junction box).
At that time (yesterday), I also noticed the sump was filled with fairly clean water. I cannot say whether this is normal... I have never really paid attention before.
Fast forward to this afternoon... My wife heard a clicking noise about once a second coming from the dishwasher. She pushed the ON/OFF button, and it stopped. When I got home from work, I verified that the dishwasher was turning the DRAIN PUMP on and off about once a second, whenever the ON/OFF switch was latched in the ON position. It will now do this with or without the dishwasher door closed. I was able to remove a protective cover in the sump from above the DRAIN PUMP IMPELLER. I can feel the DRAIN PUMP IMPELLER turning... stopping... turning.. stopping.... as I hear the controller relay clicking.
Strange thing is the dishwasher is not turning on any of the lights when I push the ON/OFF button. I would think that if it is turned on, and senses a condition causing it to cycle the drain pump on and off, I would get some sort of indication...
I don't know much about dishwashers, but I am guessing the controller is sensing water in the sump, turning on the drain pump, and then maybe sensing an abnormal condition (float switch? pressure switch?) and decides to immediately turn off the pump. Either that or maybe the pump is faulty? But I can hear a relay in the controller cycling the pump on and off....
By the way, I did check the drain hose connection to my garbage disposal under the sink and it looks fine. I have not pulled the dishwasher out to check the dishwasher-end of the drain hose...
Any advice?
Thanks,
Robert
Related Models
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacement of drain pump on Bosch dishwasher oldarmy52 Dishwasher Repair 3 03-25-2013 09:44 AM
Bosch dishwasher drain pump ntkorbjr Dishwasher Repair 0 02-10-2013 08:55 AM
Bosch dishwasher replace drain pump pocogrande Dishwasher Repair 1 04-15-2012 08:12 AM
Bosch dishwasher drain pump wiring BillLeonard53 Dishwasher Repair 0 06-26-2011 01:30 PM
Bosch Dishwasher, question about the drain pump cape45 Dishwasher Repair 1 05-17-2011 02:25 PM
