Works great, water spray is fine but it does not drain water out to the sink. I opened the bottom assembly did not see any clogging. Hose is also clean. Air gap also clean. Water does not drain to the sink but if I keep the hose on the floor water drains out (gravity) completely. What is the problem? Anything to do with drain pump?
